With no information to go on, my first guess is the S-1 combined volume pot and mode switch.
The simplest DIY solution to attempt is to spray electrolubricant into the resistance track portion of the pot. I use Servisol. Other brands are available.
My guitar is a Stratocaster manufactured in 2007. It has SCN Noiseless pickups.
No modifications has been made to the wiring circuitry.
If it’s the first then contact cleaner/lubricant should fix it. If it’s the second it’s likely to be a shielding issue or just an unusually noisy environment.
It's a strong BUZZ that gets stronger and noisier when I start moving the knob from around 3. The noisiest range is between 6-8. And yes it stays there when I don't turn it! So it looks like a shielding issue. What do you recommend?
If the ground is good you may need to check that the body cavity shielding is effective - modern USA Fenders use conductive paint, which I've always found less effective than foil anyway, but sometimes it's even worse because the screw terminal which contacts it has come loose or just never made a good connection in the first place.
I have quietened a lot of guitars with paint shielding by redoing it using foil - over the top, no need to remove the paint.
It might also be worth checking the mains earthing in your house or wherever you're playing - if the earth is poor or missing then the shielding will be less effective, although the amp and the guitar will appear to work OK.
