Loctite.
Or a 6" nail.
Either way I would replace them with standard strap buttons or locks as TheMarlin said. They’re not reliable or secure and the only reason they’re still used is for appearance.
How would you go about changing the pins over to straplocks, is it easy? How does it compare to a solid bodied guitar?
I have a Gretsch and (wrongly) assumed that the threaded pins were a good idea.
They were in about 1955... when there were no really secure methods.
In practice, it's difficult to get the knob part to stay tight without then unwinding the screw part from the body when you undo it, and the screw into the body isn't large enough either so it can easily work loose or pull out - if I need to make them work I superglue the screw part into the body, that usually prevents them coming loose and allows you to tighten the knob. They also won't take a modern thick strap, there isn't enough of a gap between the knob and the body.
It’s a good idea to remove the existing locks when the strings are off, remove the pickups (don’t unsolder, you just want access through the pickup holes), put elasticated string through the neck pin hole, thread it through the pickup hole, and through a small block of wood. Apply glue to one end and pull through the body, tighten the string, and tie off at the headstock until the glue had dried. Make sure not to foul any electrics along the way (pickup/tone switches etc - I’d remove these first).
Remove string, then install modern strap locks
Modern strap locks have longer thicker screws than the Gretsch units, and like more wood to bite into.
All Brian Setzer models come with proper strap locks as standard.
Which strap locks would you recommend?
