Mint condition Orange Rockerverb Mk II 100 Watt, one of the rare versions with the DIVO system embedded, about which more below.
Based in central London just outside congestion charge zone (Elephant & Castle). Will ship for actual cost. I have a shipped a number of amps with no problem.
Studio use only. The condition is mint, with no scratches or tears in the tolex. There is a small mark (cleanable and not visible in photos) from the feet of another head that was placed on top of it. Full description follows the images.
MADE IN ENGLAND
I've had a number of good offers from abroad but would really rather sell it here.
£799
A lot of info is available on the Rockerverb Mk II elsewhere. Suffice to say, it has a good dedicated clean channel, a flexible overdrive channel that goes from clean to just on the edge of breakup to huge amounts of filth, a valve-buffered effects loop and a lush reverb.
DIVO is an auto biasing system that allows you to use any of the large valves. It automatically biases the valves to deliver the optimum voltage. This has three main advantages:
1. you don't need to bias your amp to the valves
2. you can use any of the larger valve types - 6L6, EL34, KT77 etc.
3. You don't need to use matched sets - it will ensured each valve gets the right power, and if one is failing it will redistribute the load.
It's actually really useful and ensures the amp is sounding as good as it can at all times.
