I've got mine set up so that the MC6 turn on/off any/all of the 6 blocks, and then I set the Stomp to Snapshot mode to give me the various combinations of what I need for clean/dirty/lead boost.
Even in snapshot mode, the MC6 can still turn on/off any of the blocks without affecting the saved parameters in each snapshot
That's brilliant! Thanks.
You could setup a long press (or double tap) on the MC6 to do tuner and short press for another function.
Ebay mark7777_1
@smudge_lad - does the MC6 get feeback from the stomp when you change snapshot?
like, is there indication on the MC6 of what individual blocks are active?
No - mine is only a Mk1 too, so I can't have the on screen message showing on/off anyway. All I can set up is blink for on/off. As far as I can recall, there's no indication.
I'll check after work tonight
Let me know if you want to move it on at any point
