Put the selector switch in one or other pickup position, not the middle. Connect the meter to the end of a cable plugged into the guitar, from tip to shield.
Turn the volume control to 0 - the meter should read 0. Turn it to 10 - the meter should read the DC resistance of the pickup.
Now turn it slowly between the two - the resistance will rise to a peak, then go down again. Find the peak value by carefully turning it back and forth until you're sure you can't find a higher reading. Then multiply that number by four, and subtract the resistance of the pickup.
(This does assume that the pots are wired the normal Gibson way - if they're wired 'backwards' like a Rickenbacker, Jazz Bass or some far-east Gibson copies, simply turning the pot to zero will give you the pot value.)
@ICBM, would this also be possible using the middle and side lugs themselves, as I have noticed these will give a reading of c.115 with the pot turned to ~8?
Neck Volume: 138 x 4 = 552
Bridge Volume: 134 x 4 = 536
Both pickups appear to be 7.7 when I set the meter to 20k. So that would make them 544 and 528
Does that seem sensible?
The reason it works is that you're measuring half the resistance to ground in two directions, one via the lower half of the pot track and one via the upper half of the track and the pickup. These are effectively in parallel, so the result is a quarter of the total resistance of the pot track + pickup.
Yes. That's well within the usual tolerance for a 500K pot.
