Lately, I have taken to using a non-buffered simple non-esoteric boost pedal in front of my amplifiers. Set to a modest boost and running the amplifiers very clean.
Both my amps are Fender style clean channels (Roland Blues Cube Stage & RedPlate Blackverb)
And it sounds lovely ( and I’m talking pristine clean tone).
If I don’t use a boost pedal and I increase the gain on the clean channel somehow it doesn’t sound as nice.
For a CLEAN channel (volume only, no gain knob), there should be no difference right? Boost pedal or turn up volume should (theoretically) be the same.
On the other hand I’ve heard that it’s not the same. Using a boost into the front end of an amp is one of the oldest tricks in the book for getting great tone. You can't get the same effect by simply turning the amp up.
Expert opinions please...
If it sounds better to you using the pedal, use the pedal.
