Hi
all,
Need some help please - trying to wire up a Les Paul (2
humbuckers, 3 way swicth, 2 vol and 2 tone) with Bare Knuckle pickups,
as 50's wiring and using the weird CTS push-pull pots on the tones for
coil splitting. I wired it how I believed it should be (basically using a standard 50s wiring diagram, and wiring the CTS pots as per a post on here showing how they should be wired (C1 to ground, terminal 1 having North Finish and South Finish to terminal 1), but the coil split isn't working, the tones aren't working and the volume on the neck goes down and then back on full at 0.....).
Does anyone have a diagram please...? Thanks!
https://www.seymourduncan.com/wiring-diagrams?meta_params=guitar-options,2-pickups,neck-h,bridge-h,2-volume,2-tone,3-way-toggle,accessory-none
From the drop-down list above the shown diagram choose the fourth option (tones with push-pull coil split). Then assuming you know the small change needed to make it 50s wiring you should be good to go.
EDIT: I just saw that you have the cts type push-pull pots so for the actual switch wiring look at this:
https://www.stewmac.com/How-To/Online_Resources/Learn_About_Guitar_Pickups_and_Electronics_and_Wiring/Wiring_the_CTS_DPDT_Push-Pull_Pot.html
It's a ground plate in the cavity, so all pots are connected to ground (and the bridge ground is connected to the back of a pot as well).
Any ideas? Have both the caps leading from the lowest lug on the volume to the middle lug of the tone CTS pots.
However, when I roll the neck tone down, the bridge pup tone changes, and vice-versa. However, the volumes are correct for each, and the push-pull works correctly for each.
No idea what I've mis-wired...!
If that all checks out and there are no dry joints in the signal path then, as @Funkfingers said, photos might show a cause.
BTW a degree of interaction of the tone controls is expected with LP style wiring but not causing the bigger issues you are experiencing.
