J Rockett Archer overdrive/booster for sale. It needs no introduction really, having becoming a classic low gain boost and overdrive pedal in so many professional boards. It is not only a great sounding effect but also one of the very best buffers out there which preserves your signal as it goes through the rest of your signal chain.
It is in good condition (including the original box) and it is fully functional. It has some marks on its body from regular use and velcro on its bottom so comes ready for your pedalboard.
Price is £120 delivered. SOLD
Manufacturer's blurb:
The Archer is sort of a 2 in one pedal. It can be used as just a clean boost by turning the gain all the way down. As you introduce gain it will attenuate the clean signal but there is a magical blend in between that you will find. Please experiment!
Dimensions: 4.00″ x 2.30″
9 volt Negative tip adaptor and a 5.5mm x 2.1mm jack.
9 volt Battery
Buffered Switching
