This may be a case of "just do a full fret dress", but I figure I'll ask anyway...
My new Les Paul has a couple of frets with a little more wear than the others, specifically the G & D strings from 9th to 12th frets, so I'm keen to get that sorted. There are bugger all trustworthy techs out here, and I generally trust my own abilities, but have never done a fret dress myself, so am obviously slightly cautious.
I don't want to take any life out of the lower frets if I don't have to, so I'm keen to dress only the upper half of the fretboard. I have to put a stewmac order in anyway, so looking at picking up a couple of appropriate tools and having a go (gently and carefully!).
Am I asking for trouble?
I always prefer to do a 'taper dress' on guitars with a lot of wear in the low positions - so you're taking off more metal down there where bending isn't important, and leaving plenty of height at the top end of the neck where it is. As long as the top surfaces are all in a straight line it will play perfectly.
This is the opposite, where you want to take out a little more height over a hump in the fingerboard. It's quite easy to limit the levelling to just a small area of the neck, simply don't move the levelling file too far.
Basically I know the 13th needs to come down a little, and considering everything above that current plays fine, I'm assuming I actually need a little off everything above it as well to avoid consequential buzzes further up the neck.
I'm thinking a not-too-long radius block, a fret crowning file, plus my usual grades of micromesh for polishing should do it.
The only other thing to mention is you may want to create a slight fall-away in the last few frets ~19-22, rather than having them perfectly level. It will help you achieve a lower action without the risk of choking on the last few frets. This is however optional, depending on how low you like your action.
The plan is just to dress the tiniest amount off everything above 12th, and see from there
In the UK I’m sure there are some crap careless ones, but there are plenty of great guys who seriously know their stuff
