Thanks to the very lovely
@thecolourbox aka Matt aka Nid (Thanks to autocorrect!), I'm pleased as punch to be spending my Saturday creating patches and snapshots and pumping out some glorious noises on my Bassbreaker!
I do have one question though.
I'm aware that it has a very good looper built in, but I regularly use my Trio+ as a looper, even for live stuff, not necessarily for the drums and bass, but more for the 5 different song parts. If I do use drums and bass, they go out to my PA separately using the mixer out, so they don't colour my amp.
I was thinking of just putting the trio between the HX and the amp, rather than putting it in one of the loops of the HX or in the amp's loop. This means it will still go through the preamp and sound right but will mean I can only send it to one amp. I'm messing around with a stereo amp setup and having the loops only go to one amp will sound weird.
Given that the amp, the trio+ and the HX all have effects loops, there must be a clever way of doing this that means the sound from my amp gets to the Trio but then I can change effects without changing the loop and I can send the loops to both amps, or use the expression pedal to pan it to exactly where I want it.
I'm currently running the HX straight in, but I could use 4cm or even 7cm for a stereo setup although both are a ball ache that I'll rarely want to faff with.
Any ideas?
You could look at placing that return block on a parallel path at the end of the signal chain and assigning a pan block after it to pan the backing tracks between the amps.
Just because you're paranoid, don't mean they're not after youI wouldn't need to bother with the drum and bass return though, as that can go straight from the "mixer out" of the Trio to the desk.
Thanks, I'll give that a try
Just because you're paranoid, don't mean they're not after youThe expression pedal is indeed the cheap MAudio one off Amazon - it's plastic, it's not pretty, but it works. I didnt want to buy an expensive one then have to sell it when I realised the HX wasnt for me
soundcloud.com/thecolourbox-1
