When you fit the string, set the hole in the machinehead barrel parallel to the neck, poke the string through from the *far* side, then pull it tight and tie the loose end under the main part so the end is still pointing away from the bridge. The string should be tied to the barrel and not completely slack. Now tune it up, stretching it as you go.
You should be able to string and tune the guitar in about 10 minutes like that. It will still keep going flat for hours, that’s just what nylon strings do.
! Bastardos
Because I've mostly played nylon string, I've applied that principle to stringing my other guitars most of my life - pulling the string as tight as possible, then tuning up, so that on the bass strings on electric guitars there are no windings at all, just the string poking through . Numerous people - most recently Jonathan at Feline - have expressed surprise that this has worked at all, and thinking about it it really shouldn't, but it always did. I'm getting into adding more windings above and below the string on electric now, though, if only to present a relatively normal face to the guitar tech world.
One thing I learned from playing in the Guitar Craft tuning - A.K.A. New Standard Tuning, the Robert Fripp one, CGDAEG - is that the windings distribute the tension when the string is under high tension. The high G - usually an .011 tuned a minor third above the top string in regular tuning - would snap a lot for me until I learned to add a few more windings than I normally would.
I should get one of these things, though, if only because I like gadgets.
