Bandcamp
My favourite Strat bridge pickup is the Pure Vintage 59 though. It's quite dark - remarkably so, IMO.
Irish Tour with plate also great.
Wouldn’t swap either for a humbucker.
Look remains the same but you have more options. They're around £50
I've never got why so many have a problem with tree bridge pup, I've always thought it was fine. Maybe the fat 50s is just a particularly good one.
As much as I say just use the others, I do totally get the OCD thing of wanting all positions usable. Kind of like how I'd consider turning a Tele in to an Esquire instead of just keeping it on the bridge setting.
I think the sane thing would be to just use the positions you like but then again, the people lucky enough to think that practically are probably too busy playing music to come to a forum in the first place.
I wired a Superswitch so that Position 1 had around 1.2nF in parallel, gave a very beefy tone. I then wired position 2 for lower value of cap because 1.2 nF messed around with the sound of that position.
Was discussing this with @CasperCaster who brought round one of his strats with no pickguard or pickups, but a connector block wired in and a box of pickups and a cut down guard.
Started with the goal which was as close to my 52ri Tele bridge pickup as possible.
Spent the night working through the pickups, in output order, making notes.
There were two or three that stood out as being in the ballpark.
I ended up buying a Dimarzio SDS1 from eBay and getting it wired in with a super switch that has position 3 changed to give neck & bridge together. This gives me the three ‘tele’ style selections, along with the 2 in between Strat positions.
The SDS has loads of output on it’s own, but still mixes well with the others.
I’d like to try the FS1 at some time as this wasn’t quite as hot as the SDS.
I love neck position on a strat but in a dense mix it can sound a bit weedy and muddy.
