I my experience P90s are usually better in this regard than humbucker equipped guitars.
For the record, the stock pickups in the Paul Reed Smith are Seymour Duncan SP90-1N and SP90-3N models. (Both neck position pickups.) I "borrowed" this idea for two of my guitars.
I personally I don't like the treble bleed mod, but appreciate many do - Easy to add if required - Even try with a couple of crocodile clips initially to test drive it, then solder up once happy with it
How much gain have you dialled in?
Is that gain from the amplifier itself or overdrive/distortion pedals?
Do you connect to the amplifier via a cable or a wireless system?
Hamstead RT20
None - this is funk-clean
N/A
Cable
