I have a 1973 AC40, which has 25 Watt Fane speakers dated 1974, it's only guesswork but I think probably the origional speakers were blown and the owner didn't want to pay for new Silver Bells.
Amp has only had 1 owner from new and was used exclusively for keyboards, which the Fane Pop25's probably suited better.
Anyhow I have found a pair of 1964 Vox Blues, arriving next week.
But I have a dilema, they are 8 ohm, and my amp needs to see 8 ohms.
As I see it I have 2 options, I have a pair of 200Watt 8 ohm resistors, so I could put 1 in series with each speaker, then connect in parallel as would be correct with 16 ohm speakers.
The other way would be to put the speakers in series and the resistors also in series and wire that lot in parallel.
Either way would load the amp output correctly.
There is also another way with each speaker having a parallel resistor making 4 ohms, then put that setup in series.
Aaarrrgg my brain hurts!!! LOL
Has anyone ever had a similar situation? What do people think would be the better option?
https://www.voxac100.org.uk/jennings_ac40.htm
I've never seen an AC40, but it wouldn't surprise me if Jennings was using Fane Pops, he was always a cheapskate.
If you want to use the Celestions, I think it's very likely the amp has a 16-ohm tap on the output transformer as well, like an AC30. Have a look at the connector block on the chassis - if there are three wires, it does.
If there isn't, it will be better to run the amp mismatched and accept the slight loss of power output than mess about with resistors which will just waste even more power.
Regardless of whether they're original, using the Fanes may not be a great idea anyway - back in the old days they were commonly known as "Pops, because if you put anything like the rated power into them, they pop!" (It actually stood for Popular.)
The rather optimistic power ratings of Fanes, Goodmans and other non-Celestion speakers is why they always had a reputation for being inferior to Celestion, although in fact many of them sound very nice as long as you're careful with them. The power ratings are more like those of a hi-fi speaker, whereas Celestion seemed to understand what musicians would do to them, and rated them for 'a cranked amp of that power' - basically about double the clean rating.
other than mine has AC30 style chicken head knobs and Celestions dating to 1976 which appear original). The one in the link has Fanes, though, so your Fanes may well have been how it left the factory.
I'm not sure why spacing the EL84s more widely is useful though!
Personally, I've never found the cut control useful on any amp I've owned (vintage Vox, TBX, Tophat - it just seems to make the sound duller. Likewise, I much prefer the Magnatone vibrato and Fender tremolos over the AC30 versions. I think they got the '60s AC10 right - sounds great, lighweight, no superflous effects, Fender style trem controls. That said, I do like the versatility of the three differently voiced channels of the vintage and TBX AC30s. Horses for courses I suppose! Tele player btw.
I don't think the spacing of the EL84s makes any difference to how hot they run, the key is the ventilation in the chassis and the top of the amp. The maximum power output is limited by them being run far too hot *electrically* - ie well above the plate dissipation rating - not the bottle temperature. I very much doubt the 'AC40' actually puts out more power than an AC30 either - about 33W.
It's actually another indication that the amp doesn't put out a true 40W - that they haven't blown. There's no way I'd want to put a proper 20W amp through one, the realistic power rating is more like 15W at most.
I'm not knowledgeable regarding the overdriven behaviour of valves, other than they produce even order harmonics, which the human ear likes.
It seems to me that the relationship between speaker power handling/rating and amplifier output, is totally different from transistors.
With transistors it’s better to have more power than the speaker theoretically needs, it is then very unlikely that the speaker will be damaged, quite simply before that occurs it would be so loud it would probably be turned down.
The opposite way about, that is with an underpowered transistor amplifier, trying to get high volume is very likely to damage the speaker, as an overdriven tranny amp clips the top of the waveform, this produces DC spikes both + and -, 2 things then are likely to occur, the cone is driven hard against it’s stops, very likely to decentralise the coil, the other likelihood is the DC heats the speech coil and it could seize and or again decentralise.
