Even within Cubase I often run vocals though guitar pedal and amp sims.
It's all about what works for you and for the track, really.
It will be a lot easier and a lot less faff to manipulate your vocals post recording
If the Tascam has a balanced TRS jack socket (the manual will let you know) then a cable adapter such as this will do the trick.
If the Tascam has only an unbalanced (mono) jack socket then you may be able get away with using one of these, although one of these would be the proper technical answer.
Electro Accoustic with a Piezo, plugged into a delay pedal > amp. Shout/sing into the soundhole of said EA and listen you your voice coming back at you!
