Looking for a smaller versatile valve amp and obviously the HRD come highly recommended.
Just a few questions regarding the range.
I understand the original version had a common fault with some of the resistors failing - was this fixed with the MkIII version?
Speaking of versions, was there a MKII or was the III the replacement for the original?
Looking at the changes Fender made for the MKIV it doesn’t seem to be a huge upgrade, so is it worth spending the extra on the IV or would a good used III be a better option?
Is there anything worth noting about the range that I should know?
Lastly, are there any other contenders at the same sort of value that I ought to check out?
TIA
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
These things are down to personal taste, but I didn't like the speaker in the HRD III. I ended up putting a Celestion V type speaker in the HRD III, which worked well for me.
The HRD IV has a Celestion A type speaker as stock and I liked the sound of of the IV out of the box.
The weight of the HRD IV is a bit less than the HRD III.
I definitely much prefer a stock HRD IV to a stock HRD III (with its original speaker).
There was quite a gap between owning the two amps, so it's difficult to be absolutely certain in comparing sound of an HRD III with a Celestion V type speaker and a stock HRD IV. However, I've bonded with the HRD IV, more than I did with the HRD III (even when it had an upgraded speaker).
I only use the clean channel. The drive channel isn't to my taste for either amp.
The II is actually the most common and was made for the longest of any of them. However, as far as I remember they are not actually marked on the back as IIs, which may explain why they appear to not exist!
Personally, I don't like the III - it addressed the most common complaint about the II, that the taper of the volume controls was too abrupt and difficult to dial in a good sound at low volume - but to me, you have to turn it up *further* to make it sound good, and even then it doesn't seem to. That probably wasn't helped by the quite poor Celestion Seventy/80 speaker.
I've only heard one IV so far, and it sounded better - which may just be the upgraded speaker, I'm not sure.
So my choice would be either a used II or a IV.
All of them come set to 230V as stock, because of EU regulations. The correct setting in the UK should be 240V, and it's easy to swap it - two push-connectors on the PCB inside - which is a good idea because it makes the amp run slightly cooler and more reliably. (Including the still very occasionally problem-causing resistors and the diodes they supply.) This is more important on the Deville, but I would still do it on the Deluxe since there is no penalty.
Earlier models also have a modern Accutronics reverb tank which are prone to failing. Fender now use Ruby tanks, but I'm not sure if the change corresponds to any of the model changes - I don't think so, I think it was some time in the III. A used one may or may not have already had the tank replaced.
Five identical thin black plastic/metal insert/thin metal nut jacks is a MkI. Two of those for the Preamp Out/Power Amp In and three thick black plastic/no metal insert/thick metal nut jacks for the inputs and footswitch is a II.
The brittle jacks on the I often lose their metal inserts, but the thickness of the plastic and the nut is still obvious.
Considering one myself.
What about the special editions; the FSR, Dukes of Hazzard and George Benson flavours - are they different in any way apart from the livery?
In the main I use it clean with pedals for drive. I like it a lot but it is horses for courses because I play mainly clean in a funk / function band. For me the clean tone produced was better than a Lonestar Classic (reverb excluded). I suspect that the Jensen speaker had a lot to do with that. The Mesa had a standard C90.
It's high praise if the clean tone is better than a Mesa Lonestar. In honesty it's the cleans and lower gain tones that the amp can deliver that I'm mostly interested in. I've even thought about a Blues Deluxe too as I think they sound a little sweeter than the HRD but then they don't have the same amount of drive should it ever be needed either, and there seem to be fewer of them and command a higher price used, too.
Thanks again, I sincerely appreciate your knowledge and input.
I use then both clean live. I've done side by side comparisons and prefer the HRD IV clean sound, although the Blues Cube Artist isn't bad and I use it for rehearsals because it's lighter.
So the HRD IV wins for clean. But if I wanted to get crunch/OD from the amp I'd go for the Blues Cube Artist which sounds good to me in that area, whereas the HRD doesn't.
