I'm planning to run guitar into Helix and then sending it to front of house. On occasions I will use my EV ZLX-12P for a monitor.
Has the current Helix solved the Phantom Power thing i have been reading? Or do i need a blocker or a DI?
Whats the best, smallest, best sounding Blocker/DI thats doesn't colour the sound out there? Just need to make sure the channel i plug into doesn't accidentally get phantom power sent to it. Not the best design really.
I'm very new to all this so how would the Helix be connected up? I'm guessing XLR would be better with longer runs to get sent to front of house, and 1/4 jack to the EV ZLX?
For Home
Is it best to always run it though a speaker(s)? As apposed to headphones as i have read the headphone input isn't great and you don't get the true sound?
“I'm very new to all this so how would the Helix be connected up? I'm guessing XLR would be better with longer runs to get sent to front of house, and 1/4 jack to the EV ZLX?”
Exactly this. You can set the big volume knob to affect the 1/4” outs only so you have control of your monitor volume whilst FOH gets a constant level feed.
As for how you listen to Helix at home, there’s no ‘best’ method really. I use headphones, studio monitors, a powered PA type speaker or a Powerstage amp and 2x12 cab depending on mood and what I’m up to. It’s probably best to set your live patches up using the setup you’ll be using live though.
How would you set it up for home practice?For instance jamming using Youtube backing tracks, how would you set it up so you can have either headphones on or have everything going through a wedge where you can jam too?
I think you could probably put an ipad through one of the inputs on the helix and do the same, or I can run the ipad straight into the monitor which has additional inputs so I think I can get line in, vocal and helix all out the same monitor.
works well
https://m.thomann.de/gb/tritonaudio_phantom_blocker.htm
