There are various number patterns used for the ink codes
The 2737842 stamped code is correct - They can still be Tim Shaw's without ink markings - But what meter readings do you have - TS are normally around 7.5 - 7.8K ish as a guide line
Prices have been rising - I'm not sure they are as good as the hype - Certainly not rubbish - But I dare say if you are selling them, then you can join in with the hype - I've seen prices £100 to £150 per pick up and even more
Early LP Studios - I've seen both with Shaw and 490's or 498 and 490's
My own '82 ES-335 has Shaw pickups with very similar markings to the ones shown by @guitars4you, his being from a 1983 guitar.
http://www.es-335.com/2010/06/19/the-pride-of-the-80s-part-1/
