Here's a few suggestions (in order of what I started with and where I ended up before going digital)
- Suhr Riot
- Amptweaker Tight Rock or Tight Metal Pro
- Ramble FX Marvel Drive
- PIOD FX What You Want 2 (discontinued and hard to find)
- Bogner La Grange
- Diezel VH4 pedal
- Friedman BE-OD (the new Deluxe version has a Mid control which will help)
The last 3 were superb. Enjoy.
EDIT:
Pedals I'd like to have tried:
- Sinvertek No 5 (I think that's what it's called)
- MI Audio Megalith Delta
- EVH pedal
Also worth trying the HX Stomp as a preamp into the FX loop of your amp. A nice 5150, Marshall or Boogie may sound decent enough for what you're after.
EDIT again, I misread... you're not looking for brutal chugs...best solo tone I've had from a pedal was the Diezel VH4 pedal. Sounds beautifully thick and smooth. The La Grange is good too.
The MXR EVH 5150 is just fantastic.
I briefly owned an Emma Reezafratzitz and it was absolutely mega. I didn't keep it because I owned an actual JCM800, but damn that was a silly grin pedal and the used prices are reasonable last I saw, assuming you can find one.
I set the two amps loud in the same room and the similarity is impressive.
