I use two different rooms at our band rehearsal space, and in both rooms when I plug in my HX Stomp (using the Line 6 supplied plug), even with the patches bypassed there is some very loud background noise/interference. To the point I couldn't use it at all.
My the rest of my board seems ok, maybe a little louder than at home.
I only have a cheaper extension chord I bought from Aldi some time ago, and wonder if upgrading this will make any difference?
If so, what kind of extension cable should I be looking for? Most seem to advertise "surge protection" but is this really what I need? Or do I need to find some kind of "power conditioner"
It could be mains-borne interference, in which case you may need a power conditioner - a simple surge protector/filter is unlikely to be effective although you could try one. Or it could just be a very noisy electrical environment, in which case you have a more difficult problem to solve... it's usually necessary to find the cause of the noise and suppress it at source.
So, I took the board to bits and plugged each pedal in one by one to find the culprit, and guess what?? No noise!! So, I’ve absolutley no idea what was going on at all.
Now I need to re-wire the whole thing....
I'd be surprised if its coming from the zuma though, even with all 9 outlets in use. Mines silent as fuck.
Did you try the zuma powering 1 pedal with the Stomp too?
Wondering if theres something going on by using 2 seperately powered things if you know what I mean.
If not, the patch cables maybe?
