Some of you may have seen my thread in OT and know that I am about to have surgery that will mean that I henceforth have a stoma. So, I have been pondering the effect on my playing guitar and thinking (overthinking?) the best guitar for my needs. Well, any excuse for GAS and something to keep me focussed and occupied as I recover from the op.
I think that the guitar needs to have no sharp edges, so heavily radiussed body, probably with belly and arm cuts for extra comfort (reassurance) and as light as possible less than 7lbs perhaps.
As to type, I have been loving my GSP LPJ, so would quite like a single bridge P90, or, maybe a pair of P90’s al la LP special etc.
I like Gibson scale length, so need to factor that in to the neck and basic measurements too.
I’m guessing this may have to be a build, so who might produce a bespoke body to take either a built neck or an off the shelf neck. ( I am assuming bolt on rather than set neck if I will assemble, but I assume this adds weight?)
Who makes the lightest fittings I.e. tuners, bridge or stoptail (aluminium wraparound at c1g).
If if not a build, any ready built suggestions please?
I'd also think if it's down the junior style guitar then most likely a set neck
Doesn't have to be junior but something chambered would get the weight right down or a thinner body to start, even my lightweight dc junior is over 7lbs, the contours would bring it down though
Another suggestion is if your jnr is light enough have all the contours done on it to lighten it further
As to who to ask I'm sure a few on here would be able to do it for you like GSP etc
A wraptail bridge is probably the lightest you could use
(formerly customkits)
I was was wondering about a Tele, Stat or JM style body in a lighter wood and chambered or with a large route; with a simple stoptail and single PU or maybe PU’s.
My LPJ is quite bright and I have always wondered if it is due to the chambering, so tone wiring may need reflect such an open body.
Left field, but would something like a Steinberger cricket bat with a belly cut work better? Or possibly even something based on a V, but with some creative shaping on the top 'leg'?
I do have one you'd be welcome to try.
Just because you're paranoid, don't mean they're not after youView my feedback at www.thefretboard.co.uk/discussion/comment/1201922
@jonathanthomas24 I actually have a PRS custom 24 and agree it is very comfortable. I wouldn’t say mine is particularly light, about 8.5 lbs if I recall.
the JS700 looks good too.
i am probably overthinking this and, once healed, I will be fine. It’s an unfortunate spin off from having had to wait five weeks for surgery (I’m not complaining as this is quite quick, but it does allow loads of time for the mind to wander).
https://i.imgur.com/3jYhkV0.jpg
This is (now) Audrey's PRS SE Santana Special.
Overall build quality has been and still is superb.
@maltingsaudio - Yes, need to look at Musician.
The more I get in to this the more it feels like an opportunity for GAS!
Thanks for the support.
The stand supports the weight of your instrument(s) without the need for modifications. You just slide up to the instrument and play it. No compression or gravitational pressure of any sort on your torso.
Yeah, it will look a bit Pat Metheny (or Alex Lifeson) but it is less of a compromise than some of the alternatives.
