The fun starts when you want them to be different, and the ability to do that depends on what the controller can send and what the devices can respond to.
If the MIDI controller is a footswitch thing on your pedalboard it would seem simpler to connect the MIDI controller to the Strymon first, then send the "THRU" connection from there to the amp, otherwise you're running two MIDI cables back and forth to the amp unnecessarily.
Unless the Strymon doesn't do MIDI THRU properly, in which case use either normula1's method, or a MIDI THRU box on the pedalboard to split the signal before the Strymon.
The other advantage is that you don’t have to create as many patches on the different devices.
