OK, so the HX Effects didn't quite float my boat - close, but not quite there for me. Part of it was the lack of 'plug and play' the M9 has - there was certainly a bit of a learning curve and some effects had LOADS of parameters.
I've been thinking for half a decade that, if Strymon came out with an 'M9 Killer' (as TGP referred to it all those years ago) I'd be in, and every release the company has made since has had me thinking its more likely - or at least more possible. As far as I can see, they're missing (a) filters & wahs; (b) fuzz; (c) digital compression & (d) pitch shifting with everything else covered pretty well. And I'd suggest you could dump (a) and (d) and not upset too many people, adding them by USB update later. Surely a Fuzz "small box" and then a Drive "big box" are in the offing?!?!
Anyway, Strymon Multi - what would I like to see?
- Up to 4 simultaneous effects, with some way to have 'What You See Is What You Get' knob placement, sort of like the M13 - 4 discreet modules would be great. 3 would be adequate.
- The possibility of "analogue dry" throughout. Certain effects would NEED to be digital only but it'd be great if you could have an overdrive with some analogue dry mixed in and then a dry path through a delay and reverb that didn't go through AD/DA but I think that contradicts what I just said, so maybe not... having owned a Flint, I didn't mind the full digital conversion too much.
- All the Strymon effects (or close to), but with less tweakability - this would (a) differentiate them from the other models that allow continuous variation of all variables and (b) make finding tones simpler. For example, I don't need all the dBucket functionality of the Timeline or Brigadier, but it'd be cool to have a brighter, clearer '2 chip' delay tweaked after a DMM and a dirtier, darker '1 chip' delay modelled after a DM-2 or AD-9, with a single control mapping several factors like noise, bucket loss etc, kind of like the Volante has combined Crinkle and Tape Age into a single 'Wear' control. Doing this across the whole range would make the other pedals seem more specialist while the 'Multi' would be more utilitarian.
- Plug a standard kettle lead into it, no hassle or fussing with anything else. But I get some people want to incorporate big things into even bigger boards. How you guys aren't get around with those things is beyond me!
If we're talking Strymon, we're talking x1.5 to x2 what the HX Effects goes for, £700+ I'd guess. If it could truly replace top draw pedals, power supply and board then that's not so obscene. Getting closer to the £1k mark and it becomes a lot less appealing...
What do you guys reckon? Fantasy or possibility??
More appropriate, I think, would be a TC multi unit which brought together the Toneprint effects. They all use pretty much the same audio engine anyway, so it's not that much of a stretch. Hell, at their core they all use MIDI to communicate with the Toneprint Editor, so with a little bit of a push it could even be a firmware solution with a USB hub in the middle to make them all behave nicely with a MIDI controller.
Ebay mark7777_1
My suggestion was that the Strymon stuff became more simplified rather than trying to maintain all that complexity if being packaged in a multi effects.
Well, we don't know the cost or the quality of this fictional pedal, so how can we recommend something over it?? Is this an agreement that it could happen but will likely cost too much?
I don’t see it happening.
When you look at something like the Transistor Tape, Cosmos Echo, or Ganymede effects on the Helix, they're quite bulky.
I like both approaches personally, for different things. Strymon is more 'curated' and Helix is more 'roll your own you clever sod'.
I doubt a multi is in their business model. There are plenty of boards that show people buy multiple Strymon pedals so why build a multi that takes away from these sales. Strymon are the Apple of guitar effects, they make very good products at a premium price and deliver it in the way they want it, not necessarily what the user asks for.
It’s similar with Eventide, they could easily make 3 H9’s in one box, but if they give too much, it undermines their existing business model.
I think those who are saying Strymon wouldn’t compromise all that functionality might be right, but then as those ‘big box’ pedals hit 8 or 9 years old, surely they’ll reach market saturation for new sales and look to add new products that either simmer down existing assets (what I’m talking about here) or else produce something brand new - which I bet is the more expensive option.
