Class D power amp question
John_AJohn_A Frets: 3775
I have a Behringer nx3000 power amp, the specs give power in to 2,4 and 8 ohms, am I ok to run this in to a 16 ohm cab?
  • John_AJohn_A Frets: 3775
    Any idea @ICBM ?
  • Danny1969Danny1969 Frets: 10483
    Most class D amps are fine with no load at all as the feedback pulse width is adjusted to suit load .... lighter 16 Ohm load means less current and switching ratio is adjusted to suit
    Have to say Behringer don't always follow good design strategies  though  ....seen some aweful class D Behringer amps
    So that's Yes, probably, maybe not ;)
    Be fine IMO
    Be fine IMO
    That's what I thought too - Cheers
  • ICBMICBM Frets: 72764
    Sorry, late to this - but yes, it *should* be fine. If in doubt, you need a 16-ohm load box to run in parallel which will bring it down to 8 ohms.
