Recently acquired this Stratocaster and the headstock number dates it as 1979 and pretty sure the body matches the neck but how do i know if the pickups and harness are original? Clearly its not an original scratch plate but when i put the pot' number into the Guitar Dater Project it said unknown, and when i dropped the R off the front of the other 6 digit number it came back as 1949-59??
I'd have thought that if i'd been lucky enough to get a guitar with 50s strat components it'd have cloth wires instead of the plastic sheathed birds nest shown below! Although there is a little bit of cloth wire between the 2 tone pots.
I know the 70s guitars weren't as highly regarded as the earlier and later guitars but the soldering on the volume pot is a bloody mess, would they really turn stuff like this out?
More photos would be helpful in terms of body originality.
If you carefully lift the tone cap you should find a readable date code there - it's the 7-digit number starting with (R)137, the next two digits are the year and the last two the week. Going by the partially visible one on the lower tone pot it could be as early as '75 (43rd week). The one on the volume pot may have its year visible too, even if not the week. The pot code date will be earlier than the production date of the guitar, but anything earlier than '78 and I would say the pots are not original to the guitar if the neck has a 79 serial number.
Hmmm.... Replaced pots me thinks!
The only full number i could read is on the neck tone pot and its R1379512, volume is R13796 solder over last digit and the bridge tone all i can make out are the last 3 digits as 543. Not all bad news, I wont feel so bad putting a nice fresh harness in it now!
Any way of knowing if the pickups are original at least?
A couple more pics.
Yes, the pickups look original I think.
All part of the 70s character .
It also doesn't seem to have one on a '78 that i found on eBay.
Your guitar will never be all original again, so mod/tweak as required - As long as you keep the body/neck original then other tweaks should have little impact on the value - Keep parts you have in case you ever want to put it back
Equally if you like it as it is then all well and good
It was a gift, belated 40th from my best man, so i'll never sell. He was sold it as an all original '78 and I haven't the heart to tell him but like i said i'll never sell it so no harm no fowl.
I believe he paid £1600 with non original case so strong money but the body and neck are in great condition, bloody sight better than my 40 year old body!
I was really impressed by the harness i put in my Mexican Tele' by James' home of tone so i'll probably treat it to one of those and then when I've the time strip and rebuild the current mess that in there at the mo. Maybe use it as the starting point for a new build!
I see no issues with such a few tweaks to improve the overall playing experience - Very rarely do I see a good re-fret not improve the overall playing experience - So something to consider another day - Nothing wrong with the pots you already have, assuming they are working fine
https://www.sixstringsupplies.co.uk/prewired-harnesses - if looking elsewhere via @sixstringsupplies
Be thankful that the body hasn't been routed for humbuckers, which is the most common reason for replacing a pickguard on a 70s Strat. It's a shame about the extra screw holes from the new guard, but those could be filled and touched in reasonably well if it bothers you.
Not overly worried about the screw holes, in fact I quite fancy the idea of getting a nice nitro relic job done on it one day when funds allow.
