Marshall 9200 power amp
Fishboy7Fishboy7 Frets: 2214
Yikes, is this the going rate for one of these now?
I think I sold mine for like £350.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/113532120136
  • ICBMICBM Frets: 72567
    No.
    £500 max. The last one on Ebay went for £350 too.
  • sweepysweepy Frets: 4195
    Another eBay dreamer, they are heavier than the Sun though
  • Fishboy7Fishboy7 Frets: 2214
    Ah yeah.  I see there is another one one there with starting price £125.
    I would get one again if I ever decided to try the digital/modeling route.
    Why? As sweepy said, they weigh an incredible amount. They do sound good, but you could just get a decent modern power amp which would do the same job at a fraction of the weight.
    They're so heavy they’re actually difficult to mount in most rack cases without extra support. You really need a full pro tour spec case and put the amp at the bottom.
    edited April 2019
    If you go back to a modelling setup I wouldn't get a valve power amp personally. The best sound I've had do far has been an Atomic CLR and that's trying various amp and speaker setups
    Yeah, to be honest I don't know anything about the modern alternatives.
  • Looks like the seller may have been hit on the head by that particular power amp.
    A fryette power station is a good bet if you want a valve power amp.
    You would need two if you want stereo though - and it’s only 50W.
    OK, very few people need 2x100W, but if you want that much volume you can get something like a Matrix GT800FX, which is 400W per channel and weighs 8.2lb.
  • FenderishFenderish Frets: 47
    I find them beautifully looking (9100/9200 etc.) but don't really see the point of these in a rack system. I could buy one if I came across but it would be more a collector/design thing than for what it's meant for...
  • fretmeisterfretmeister Frets: 24574
    85 lb.
    That's nearly 40kg.
    Nope!
    85 lb.
    That's nearly 40kg.
    Nope!
    It made my Rack into a Geoff Capes training regime ;)
  • FelineGuitarsFelineGuitars Frets: 11626
    I have a Marshall 50 watt version for sale if you want to get back into that route...bedroom use only (literally although not used as a marital aid), although it comes in a full aluminium rack case (3u)
