A mate of mine has lent me his Fender Blackface Princeton Reverb to have a bit of a play with. Unless I'm mistaken, these are generally considered great amps, but I'm not sure if I'm quite getting all of it?
First of all the reverb is amazing, I have played one briefly before and it is still the best spring reverb I've ever heard. The cleans are always pretty impressive, but it can be very bottom heavy, I assume the 10" speaker contributes to this a bit? It's also got rather a lot of top end. I'm using my Strat with vintage output single coils and running it at practice levels with the bass on about 3 and the treble on about 4.
Where I'm running into issues is using drive/fuzz pedals. I tried a variety of drive (TS, Hudson Broadcast, Sweet Baby etc) and fuzz and it just sounds a bit brittle/harsh and lacking in warmth. I think I am missing a middle control to crank up in these situations. Are drive pedals just not that compatible with the Princeton? I understand the Princeton sounds great cranked into natural breakup, but that's a bit too loud to do at home. Is it an amp that needs to be cranked to get the best from it?
I have bass at 1 as its really bassy, treble at 5 and if I can't be bothered to plug in the footstwitch then I have trem and reverb at 1 too.
Loves a tubescreamer although I have tone at 9 o clock, also loves my very light overdrive and my marshall compressor. Sometimes I leave the board and go through a joyo amercian sound which you can match to sound exactly like the princeton with more gain.
With no pedals it breaks up on 3 with humbuckers.
The amp actually does have a middle control, it's a fixed resistor internally equivalent to a setting of about 7, so it's not that. The mid-scoop is part of the overall voicing - if it's still too bassy and trebly you can turn those right down, but you'll never remove the basic character of the amp.
That's with a Princeton at low volume, when you CAN run the amp at halfway or so they all pretty much smooth out nicely.
My favourite was the Nobels ODR-1, which sounds like it's switched off until you raise the gain. Not the nicest flat out drive ever, but you can set it to sound like a Princeton with just a hint of drive and compression.
You can of course spend 200 quid a time on "boutique" pedals, but it's still the same lottery with a Princeton.
PRRI sound great with drive pedals! The stock speaker in the '65 is pants though and needs swapping out for pedals.
Ragin Cajun is good.
Here's mine years ago with a SHOD.
This is at least partly down to guitarists (possibly all humans) irrational aversion to turning things right down. Why run bass at 3 and treble at 4 if you find it too bassy and trebly? Nothing wrong with turning them both down to the minimum. However I supsect that it is probably not the right amp for you - what you are describing sounds like a typical PRRI. Some like that sound, others don't.
