Hey guys,
just wondering if anyone had input to offer on that potential configuration: overwound bridge single (maybe 7.2k or so) paired with vintage output neck and middle (5.6-5.8k, that sort of thing). All standard design.
If you've done it, did you have balancing issues between the bridge and the other pickups (without completely decking the bridge pickup)?
I've never had a big differential, maybe 6.1k to 6.8k, so I'm wondering if moving further in both directions will have unsavoury consequences.
Thanks in advance!
Click here to see me butchering some classic solos!
In essence if you had 3 identical p/ups - all say 6k - The neck pick up will appear to be louder - Greater string vibration near the neck pick-up, that creates a stronger single than near the bridge
therefore a 7K bridge pick-up should be capable of matching a neck pick-up around 5.6k ish
Remember you can adjust p/up height a touch, as required
But should present no issue at all
That way, it is not necessary to adjust the pickup quite so close to the strings.
Another consideration is that I often play fingerstyle or hybrid pick and fingers. The dynamics are different to plectrum style.
Many still like a traditional vintage 6kish pick-up in the bridge, then use a pedal as and when for more bite/output etc
Some players want that hotter bridge pick-up - With that in mind, then 7ish is subtle, as many will go over 9-10K maybe ceramic magnet
Some will add, or select a bridge pick-up with a base plate to get something extra
Depends on playing style, tonal character required, hi-gain or less gain, how rock orientated you are as a player
And yes my bridge pickup is and always will be wired to its own tone control.
Even on full 8.4 output I wouldn’t say the bridge is substantially louder - it’s just fatter, which does give a bit more drive with crunchy sounds. I also have a base plate on the bridge pickup.
However I also really like the bite from the tapped bridge output, especially for cleaner sounds, which is why I have a push-pull coil tap on the tone control.
On bridge+middle setting, switching between tapped and full bridge output makes surprisingly little difference to the jangly out-of-phase sound.
An option would be to wire it up separately and have a master tone
(formerly customkits)
