Fender Champ 15G
ecc83ecc83 Frets: 1640
Trying to help someone on another forum with a dead 'un. Anything known? Is the output IC vulnerable?
Dave.
  • ICBMICBM Frets: 72763
    edited April 2019
    It's a TDA2050 so it should be pretty robust in theory, but in practice they aren't always!
    Can't remember anything else I've ever come across with one. It's a very simple amp, not a lot to go wrong.
    You've probably found this already - https://www.thetubestore.com/lib/thetubestore/schematics/Fender/Fender-Frontman-15G-Schematic.pdf
    Check the headphone and extension speaker jacks first though - as usual the main speaker is fed via the switch contacts in both.
  • ecc83ecc83 Frets: 1640
    Thanks IC. Yes the poster had found the map. The amp does not work but, typically on a forum, no diagnostic process has yet been given.
    He was concerned about two "burned out resistors" They were in fact two diodes in the PSU bridge. Yes the print was a bit cooked but I doubt the diodes had in fact failed.
    No worries! I am not going to get deeply involved.
    Dave.
