Having recently|(ish) got back out playing and joined a new band and after a few rehearsals made it clear (to me) that the Katana I had wasn't that great cutting through and especially when I added the Line 6 M13 into the mix. It was great at home, but once cranked up it all just went a bit 'meh' and didn't inspire me. I tried various settings, tones, even using a second amp but it just wasn't quite right.
So...I started googling (as you do) looking for something reasonably priced, with good head room and just a great clean sound without too many options. Having previously had a Hot Rod Deluxe I assumed I wanted something Fender flavoured, but couldn't be bothered with the weight of an HRD and didn't fancy the Blues Jr.
I can't even remember now what was my second choice in the end, but I came upon a second hand Blackstar Artis 15. Now...no-one in the world seems to use them so getting info that was relevant was a bit of a challenge, however the feature set looked just right. Not too big, (allegedly) great tones, simple set up, 2 channel etc etc. This one was also in blonde which I think for my Mod/ Indie/ 60s band will look great! So...I took a bit of a punt having listened to some you tube clips.
It arrived and plugging in, straight away it's marvellous. Really lovely clean tone on channel 1....slightly pushed mids on this one, with just a simple volume and tone control. Channel 2 is a bit more featured with Volume, drive, bass, middle, treble then the ISF feature. I wasn't sure about the ISF feature to be honest, but in use there are plenty of options depending on what you like so I think I'm going to like it.
Overall (and I know this is only a couple of days in and I've not used it at rehearsal yet) I really really like it, and am a bit surprised there seems to be very little use of them. I've also managed to set it up with a second cab (an Orange PPC112) for a bit more spread if I need it, and just because I could!
Anyone else using one?
https://i.imgur.com/g8Y9uxb.jpg
It's truly superb. I was honestly amazed by it having previously played a lot of blackstar amps and not being too impressed
The middle-focussed voicing of the Mk1 Venue range is history, btw. The Mk2s are a totally different design, from the pen of a different designer. The new HT20 mk2 is pretty spectacular imho and the vertical 2x12 is wayyyyy better looking than other makers’ recent offerings... but hey, just my opinion.
Who you playing with?
It only has one input jack... in fact, the entire panel layout and feature set is identical to the earlier HT20.
Including the rather awkwardly-positioned master volume and reverb controls.
It doesn't mean it sounds the same of course! From what markslade07 says, I very much suspect that it doesn't.
VERY different sounding amps.
Cheers Rich. Playing with The Roughcut Rebels...Devizes/ Chippenham based...might get down your way at some point though.
Yep, they are a bit odd...but set and forget so not too worried.
Ive not played an HT20 so cant comment on those, but this one is definitely not muddy (to my ears anyway).
