Thick as shit question - will any kettle lead work to power an amplifier?
Feel really stupid asking this, but my new Mesa turned up from the seller without a kettle lead - can I just order any bog standard kettle lead from Amazon and it not blow anything up?
The ones on there say scary things like 13amp and 240v and C13 6A and all sorts...so I'm a bit wary!
I probably have a few lying about here, but can't be arsed to look for one.
  • PhiltrePhiltre Frets: 4175
    Depends on the amp. How much water can it hold?
    Sorry...
    Good question, though. I'd also like to know.
  • FenderishFenderish Frets: 47
    edited April 2019
    any undamaged IEC / mains lead will do. Amps don't go above 3 to 4A  at most (and most under 2A as per the mains fuse) and I don't know any lead of this kind under 6A
  • EricTheWearyEricTheWeary Frets: 16299
    I think we've had this before but why are they called kettle leads when I've never seen one on a kettle?
  • sweepysweepy Frets: 4195
    Kettle leads have a notch in the bottom, whereas IEC leads don’t
    edited April 2019
    Old kettles had this type of lead. I seem to remember band mates actually did use kettle leads in an emergency.
    rice cooker lead maybe :D ? Here in France some call it a computer cable ! :D
  • 57Deluxe57Deluxe Frets: 7344
    Yes, but you have to wait about 3 mins before you can use the amp on power on
    <Vintage BOSS Upgrades>
    8reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • Fenderish said:
    That's a no brainer isn't it. My OCD would have to have that lead if I was an Orange amp owner.
  • KittyfriskKittyfrisk Frets: 18947
    2 minutes with a blade & then they do  ;)  No children or dogs were harmed in this experiment.
  • ecc83ecc83 Frets: 1639
    "KETTLE" leads are a special high temperature version of the stadard 3 pole IEC mains lead. No need to go to Thomann, B&Q or any electrical shop will have them as will music stores, PMT say.
    Note, peeps often get worried because the cables are rated at 10 amps but are often fitted with a 13A fuse. Does not matter, the cable is easily capable of standing the fusing current of a 13A fuse. In fact a 13A fuse will blow in a 5A cable and the cable be perfectly fine.
    Dave.
  • zepp76zepp76 Frets: 2534
    My used JTM45 came without a kettle lead, I emailed Marshall asking where to get one from and they sent one out free of charge, not bad customer service! Maybe worth a try doing the same if Mesa have a U.K site?
    Tomorrow will be a good day.
    Find any local FE or HE college that has any quantity of IT kit. Go find a technician (friendly or otherwise) & ask nicely for a lead. If they are any good at all, they'll have a box of spares that they'll be pleased to get rid of. I must have given away hundreds of such items.  :3
  • prlgmnrprlgmnr Frets: 3992
    More likely to charge you £100 because it's a very special one with carefully selected components.
  • fretmeisterfretmeister Frets: 24573
    Mesa cost was probably £5
    Westside Distribution will then add £95
    2reaction image LOL 0reaction image Wow! 3reaction image Wisdom
  • p90foolp90fool Frets: 31650
    I have a two-core one here, so no, not just any lead will do. It's a moulded plug too, so there's no way of telling without a multimeter or cutting one end off.
  • I’ve got three ‘kettle’ leads plugged into a 4 way socket that I am too lazy to put away properly.
    I run them into my laney amp, my pedalboard power supply and another sometimes into a second amp.
    One of the 3 leads sounds remarkably a lot better plugged into the laney than the other 2 for some unlogical reason.  Reduces the hum and hiss.
    Room for one more there to power a kettle when you fancy a brew.
  • GrunfeldGrunfeld Frets: 4044
    Fenderish said:
    fits perfectly an Orange Amp
    Guilty as charged!
    Not OCD though... just makes finding my amp and pedal board kettle leads really easy to find when it comes to breaking down after a gig.
  • ICBMICBM Frets: 72567
    You may be joking, but do NOT do this.
    The purpose of the notch is to prevent you putting a standard IEC cable into a kettle, because the proper kettle ones must be rated for a high temperature. A standard IEC plug may melt if you use it with a kettle.
    It's absolutely fine the other way round.
    The other two probably have faulty earth connections - it may just be that the 'fingers' of the contacts inside the hole may have been opened out too far so they aren't touching, or the problem could be at the plug end - or the good one is a specialist cable with suppression caps in it.
    There is no other way a mains cable can affect the sound or the background noise of an amp.
