The concept of playing my MIM Jaguar should suit me perfectly, short scale length easy on the wrinkley fingers & it hangs perfectly on a strap, the switching combinations are perfect to my mind & the slightly weaker bridge pickup has been swapped for a JB mini. As I’ve had no success in selling it on & cutting my losses I’m trying to understand where the problem lies, my only conclusion so far is the radius of the neck & my left hand are not getting on, my other guitars are a LP std or PRS cu24 with flatter boards & I have no problem with either. The poor old Jag just seems like hard work, any ideas anyone? Forgot to mention it’s currently strung with 10-46, have tried 9’s but lost some tone & the feel wasn’t much different.
Some guitars are harder to play than others..e.g. Strats are notoriously harder to play than Les Paul's and a lot of people struggle to switch between those. Others are so used to Strats they cant adapt to Les Pauls. Sometimes it's also about realising that different guitars are most suitable for different styles so trying to play the same things on them in the same way may not always be the best approach.
Then there's always the possibility that a guitar is just wrong for you. But invest the time and effort with it before being sure of that...you might just gel after all.
I've tried persisting with several guitars I "should" like (usually Les Pauls) & they always get sold on sooner or later. The opposite has happened too- I've got a cheap pink SG Jr that I know is a bit rough, but for whatever reason it just makes me grin when I play it.
Sometimes it's something intangible.
Get rid & chalk it up to experience....
Buy a Jazzmaster. ;-)
Both of the stock MIM pickups are weak - partly out of trying to adhere to vintage specifications and partly because they are crap.
This will certainly up the output from the bridge/Treble position but it will also detract from the unique Jaguar sound.
I loved it in my late teens / early twenties, but these days I find it very difficult to play due to the short scale and narrow nut - the strings and frets are all just too close together. It's a shame 'cos it's a perfect shape for my metal covers band
Look at the height of your strings too.
I happily go from classical, to a jaguar, to a 345 to a Parker fly etc.
If they are set up well you won't really notice the board radius.
When I first had a jag I used to over reach with my fretting hand because I wasn't used to the scale but that soon went after an hour or so.
