It's one of the 90s models with white knobs (35W, 2 x10) and has been 'Moyer-modded' to take it back to what I believe is a Vibroverb circuit. It's my gigging amp and I'm very happy with it, except that it breaks up a touch early. I can live with it, but if there's anything that could be done to give me a bit more headroom it would be of interest. I already swopped the power valves to Svetlana Winged C and that helped. I've tried 5751s instead of 12AX7s in V1 and V2 and they 'thinned out' the sound a bit too much for my liking. So I've got JJ 12AX7s in there now. The Speakers are Jensen P10Rs.
Apart from the above, is there anything obvious that might give me more headroom? Any valves that people swear by? Any maintenance or component changes? (As you can tell I'm not an amp expert).
Cheers All and a Happy Easter!
For example the Jensen Tornado and Electric Lightning are both 97dB, 2dB more than the P10R. That would be like increasing the power of the amp by more than 50%. Some Eminences are even higher, for example the Ragin’ Cajun which is 100dB... that would be like tripling the power compared to what you have now.
Some of these will change the tone of the amp a lot too, which may or may not be what you want - if you don’t, it’s probably better to stick to one of the Jensens.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
This will, however, make 4-4.5 'louder' so you will find yourself running the amp on a lower dial setting to achieve the same volume as achieved now.
I'd recommend a mix of WGS G10C and G10C/S
Rift Amplification
www.riftamps.co.uk
If you put it in the side of the amp under the input jacks it will also balance better when you're carrying it .
