Weird rattle...
ChuckManualChuckManual Frets: 692
My Strat has developed a weird rattle. All the hardware is absolutely rock solid. The only thing I think it can be is the truss rod. Do they ever come loose? It’s never happened to me with any guitar before - plus, I’ve never heard of it happening to anyone-else.
Is it actually a thing?!
(All other suggestions as to what it might be will be greatly received too - Cheers!)
Not much of the gear, even less idea.
  • richardhomerrichardhomer Frets: 24843
    I’ve had this on a couple of guitars in the past - a slight nip on the truss rod will often cure it.
  • Philly_QPhilly_Q Frets: 23041
    edited April 2019
    Yes, I've had a rattling truss rod.  Can't remember what guitar it was - possibly an American Standard Strat.
  • King85King85 Frets: 631
    Are all the grub screws for string height touching the bottom? I had a buzz that was driving me mad and turned out to the this
  • SassafrasSassafras Frets: 30301
    I had a 70s Strat with a bullet truss rod that used to rattle. I spent more time tightening it up than playing the damn thing.
  • ICBMICBM Frets: 72549
    Is it one with a neck tilt adjuster? Check that's tight too.
  • ElwoodElwood Frets: 455
    Definitely check it's not the springs? If one is very slightly less tension and the hook at an odd angle, they can rattle.
  • ChuckManualChuckManual Frets: 692
    Sorry - should have said; it’s a hardtail. There’s no springs to rattle!
  • NickLNickL Frets: 153
    I've had that on my '90s USA Strat, with the bidirectional truss rod when it was in the slack bit in the middle of the adjustment range.
  • vizviz Frets: 10718
    Do you have one of those plectrum holders stuck on the back of the headstock?
  • thermionicthermionic Frets: 9671
    You don't play in a Happy Mondays tribute act by any chance?
    https://news.images.itv.com/image/file/1148659/stream_img.jpg
    On the rattly-truss-rod guitar I had, if I tapped quite hard on the back of the neck the rod made a sort of clanging sound.  That helped narrow it down.
    edited April 2019
    Ah! Problem solved!
