Yes - especially when you get into the range of output transformer bandwidth narrowing and valve rectifier non-linearity.
Short version - because turning up the volume increases distortion and compression in the power stage* which sounds like more gain and turns the sound to mush.
(*And speakers, usually.)
One of the reasons I tend to like much more powerful amps than I would ever need in volume terms is exactly because they *don't* do this as much. If you need more or less volume you can just adjust the final master volume/level control and not need to compensate by adjusting the gain or anything else. If you’re running a 100W amp at 10W or 20W there’s really no change in power amp or speaker compression.
Are you turning the gain down because things start to sound harsh, or are you turning the gain down because of responsiveness issues, or are you turning the gain down just because that's the received wisdom?
One of the things I have to explain to him is how amps are to be used. I don't want to go down the line of "You should do this because I do this!". I want him to understand how to use his gear.
Note: he hasn't got an amp yet
no - Tone...
My take on preamp gain vs overall (master) volume: for most amps, if you play at low volume and you want a distorted sound from the amp, you have to rely on preamp gain/overdrive. Often labeled input gain. When you gradually increase the (master/output) volume, other components of the amp get saturated and add distortion to the signal (as mentioned above - PI tube, speaker, OT etc). In order to compensate, you'd back off the preamp gain gradually.
You can hear the sound of the whole "system" reach saturation gradually with non-master volume amps. Here, there is not distortion at all usually at low volume levels.
But unless you monitor and compare the signal with a signal analyzer/scope, there is really no formula on how to set the preamp & master amp.
