Squire Affinity and Classic Vibe built to same spec?
longjawlongjaw Frets: 424
Since it's bleeding impossible to find a decent neck for the Classic Vibe Tele body I've recently acquired I was thinking about buying a second hand Affinity Tele and using the neck off that.
Anyone tried this? Are the neck pockets the same dimensions?
Cheers chaps!
  • mrkbmrkb Frets: 6964
    Yes all Tele neck pockets should be the same. I have a maple classic vibe Tele neck from a thinline, I’ve swapped it for a rosewood one, would be willing to sell if you’re interested.
    Karma......
    Ebay mark7777_1
  • longjawlongjaw Frets: 424
    Cheers bud, forgot to say in my post I'm left handed, not sure if you are?
  • Adam_MDAdam_MD Frets: 3420
    Why is it proving difficult to find a neck for your cv tele?  I've had a few different necks on mine.
  • FunkfingersFunkfingers Frets: 14640
    I advise against this. It is wiser to get a neck of at least as high quality as the body.
    I'm left handed
    Three guesses as to why it is bleeding impossible.
    There can be some variation - not least because USA instruments use Imperial measurements and Asian ones tend to be Metric.
    Where there is a mismatch, an under-sized pocket can be enlarged and an over-sized pocket can be shimmed along the sides.
  • VeganicVeganic Frets: 673
    Just use a right handed neck.
    Source: an left handed but would use a right handed one if I had to.
  • SlopeSoarerSlopeSoarer Frets: 856
    You may or may not know but affinity necks are generally 40mm at the nut whereas CV's are 42mm. Personally I don't like the narrower nut.
    edited April 2019
    Well that's that idea out of the window, I'm not a fan of narrow nuts!
    Thanks for the heads up ;-)
    It's about time manufacturers had some sort of consolidation as there is far too much to choose from out there.
  • KittyfriskKittyfrisk Frets: 19181
    And that would help make more money how?  ;)  :)
