The part that gets me is why everyone lusts after CS Fenders which afaik are not given any special treatment on the production line yet cost up to £2k more than the standard US range. Even more crazy when the “masterbuilt” ones are done the same as above but are then finished by the individual builders yet prior to this are given no extra special attention. Then you’re into £5k.
A lot of it is marketing nonsense. Add in the overheads of running a massive US based company with a load of employees and the costs soon add up.
There are far too many variables tbh. I’m pretty sure I heard in a video on YouTube that a fender takes 30 days to make. Bearing in mind they all start out the same way there’ll still be some variation the end of the process.
• Youtube - https://www.youtube.com/@Goldeneraguitars
I can make a body on my pin router in an hour or less if it's prepped up
(formerly customkits)
Wow!
Remember I'm asking about mass produced: )
Ford probably knock out a Focus in less than a week,
https://i.imgur.com/Rhdh6mp.png
I'm not sure those two comments add up, unless they have a lot of staff!
I would be very surprised if it took any more than 10min to knock out a complete batch of bodies. Then onto a sander where they're given a quick hand sand before being ready for paint. The longest part of the process will be paint, and waiting for it to dry.
Necks are more involved, but again most of it can be automated. Profile machines will do the bulk of the wood work, Big drum sander will profile a neck in a couple minutes, fret slots cut on a dedicated machine in a single pass, pre-cut fret wire can be knocked in in under a couple minutes per neck, frets then profiled quickly on another dedicated machine.
Once you're into real mass production, dedicated machine cost can be very easily justified.
Using a body as an example, as @Danielsguitars says he can do a body in under an hour on a pin router (aka a very basic profile machine). Now imagine you do the same on 6 spindle profile machine, for the added time of loading 5 extra bodies, you've just done 6 bodies in one pass. Now add a hydraulic copy attachment where you just need to simply run over a master template (think like the curved jigs home builders use for putting radiuses onto necks using a basic router), you could probably easily half machine time. Now automate that process, and for those 6 bodies, the only human time involved is loading the blanks, and unloading the bodies. The machine will likely cost upwards of £250k, but you've just eliminated 95% of the labour needed to machine each body.
For true mass produced guitars, I'd say actual hands on time will be under a couple hours, and probably even under an hour for some. Everything else will be machine time, drying/curing time, and simply queuing time as parts are held awaiting assembly.
Given that their (plasticised) nitro is usually laid on a poly or acrylic base coat I don’t think they’ll wait long for them to dry either.
For example, if "painting" takes 2 days you can produce one guitar every 2 days, even if the entire process takes 3 weeks. Edit: Assuming you have the ability to run every step simultaneously and can therefore keep every stage of the production line filled.
If you want to increase your rate beyond that you'll need multiple production lines, or processes capable of handling more than one guitar at once. The very definition of "mass production"
Interesting though using Fenders statement of being able to produce 550 per day, how come the market isn't saturated (and that's just Fender)? No wonder people have so many guitars!
Just doing a simple search on eBay it shows about 1600 used Fender's, 990 used Gibson's (other brands are available) currently for sale. How come when they are produced in such great numbers they manage to retain so much of their value? I suspect some of the recent older ones (i.e. not truly vintage) are selling at about the price they were when new.
