But what about nuts?
I'd assume it doesn't matter once the string is fretted but are there any benefits to Corian over tusq over bone etc?
The Bigsby was the first successful design of what is now called a
whammy bar or tremolo arm, although vibrato is the technically correct
term for the musical effect it produces. In standard usage, tremolo is a
rapid fluctuation of the volume of a note, while vibrato is a
fluctuation in pitch. The origin of this nonstandard usage of the term
by electric guitarists is attributed to Leo Fender, who also used the
term “vibrato” to refer to what is really a tremolo effect.
Seriously, how often do you play an open string. If anyone is seriously worried about the difference between open and fretted notes then use a zero fret.
IMO above the material of the nut, the most important aspect to a nut is how well it is cut. Getting the 'correct' string height at 1st fret is something which is often overlooked.
(formerly customkits)
this should keep you entertained for 5 mins - PRS talking about his nuts
Seems weird but there are no more mammoth’s that can be killed and there has been tonnes and tonnes of mammoth tusk found.
I’ve used in on a couple of acoustic builds and it is very nice.
