My new pickups are:
Iron Gear Blues Engine (N)
Iron Gear Jailhouse Rail II (M)
Iron Gear Dirty Torque (B)
I have a 5 way blade switch
DPDT Mini Toggle (for coil split)
1 X Pot (LOG) - Tone
1 x Push-Push Pot (LOG) - Volume
.022uf orange drop capacitor
22awg pretinned wire (cloth)
Tinned copper wire
The Jailhouse Rail II is a blade single coil, so a mini humbucker.
In terms of setting for my iron, what should it be set to?
Just trying to work out the wiring for it in advance
I'd like to split the neck and middle humbuckers. Bridge to be left as just a humbucker.
I'd like the tone knob to control the overall tone for all the pickups.
The volume knob to have a PUSH-PUSH pot.
I'm thinking this:
The tone pot gets less use than the volume. Hence, it will take longer to wear out.
The resistance track and wiper on “dime” pots tend to be less precise in use.
If your guitar has a vibrato system, the arm and the tone pot should be out of each other’s way.
If you only want to split two of the humbuckers you can simplify the wiring buy using one side of the side of the switch per pickup. Then the 5 way can be wired as normal.
As for the earthing, all onto the back of the vol pot is standard. You need to be careful not to cook the pot. Silly question: is the cavity deep enough for the push push pot?
The only reason for going via the pickup selector switch would be if you wanted to split all three pickups.
If you don't use the pickup selector for the coil splitting you can then improve reliability of the main switching by paralleling the two sides of the switch as well. (Connect 4-5 - ie do *not* remove the link - 1-6, 2-7 and 3-8.)
As Funkfingers said, I would make the tone control the push-pull since push-pulls can have poor tapers, as well as for reliability.
In terms of grounding, would it be like this (the grey wires I added - with the final point going to the ground on the jack? Also to ground from the bridge to pot...
And on the Push-Pull - where the grounding is - do I ground BOTH contacts in the above?
In the interests of neatness, I would use the side of the pot chassis or the switch casing. The path to ground will be completed by the connections leaving the third terminal on the pot.
