I've had a Hotone Wally just as a cheap one to see if I get along with the whole looping thing. There are occasions where I think I might be able to make use of one in a live setting when I'm the only guitarist. It might open up a few song options that are a bit flat when trying to make do with a single guitar.
Anyway, the looping part is fine but the Hotone is definitely not suitable for three main reasons, only one of which is my fault.
1. Sometimes it's noisy enough to be unusable. This is a sporadic, bad earth type buzzing that seems to be totally random. I'd have sent it back as faulty if it had been expensive enough for me to be bothered and I wasn't just dicking around with it.
2. When erasing a stored loop it plays it for about half a second before deleting it. That's not going to fly in a performance situation.
3. It only has one button. And I simply cannot be arsed to put the effort into remembering the tap combinations for each function as well as trying to play guitar and possibly sing at the same time. I know this is my failing but surely it's not something I have to put up with?
Ideally what I am looking for is a looper with dedicated foot switches for play, record, stop and undo, and if I'm being really greedy two separate loops so I can have verse+chorus and switch between the two. And the icing on the cake is that because it probably won't get massive practical use I don't want to pay the earth for it - £250 max. would be favourite.
So I've been looking, on and off, for probably a couple of years and I'm coming to the conclusion that what I'm after simply doesn't exist. The main sticking point seems to be the multiple switch requirement. The thing that seems to come closest is the Line 6 JM4, but that's got a shed-load of extra guff on it that I really don't want or need. But maybe I'll have to put up with it if I can't find anything else.
Any suggestions?
It is pretty much the opposite of the Hotone size-wise though!
I think I'm going to put it back in the box before I open the door and boot it to the far end of the garden .
I cant understand how Boss have made their loopers so difficult to use. They completely remove any of the joy from the experience.
I use the digitech or the delays for electric guitar and the RC30 for acoustic/voice loops (only one with mic preamp and +48v)
but yes, the RC30 needs more user manual learning
Some people may find it easy to use, I don't know... maybe it's just me.
It's frustrating - it should be exactly what I want, but either I'm just getting old and not very good at learning new complex sequences of things, or it's really illogical and unintuitive to use. It could be the former though...
For a more balanced opinion you may be better asking @Fenderish though .
It’s the two-pedal one, by the way - the single pedal is the RC-3, which I haven’t tried, but I’ve had the older RC-2, and found that frustrating too. The one I like the best is the RC-1, but it’s also very basic.
I did buy a Trio+, but I've only used it twice, as I really need to sort out enough cables to get everything connected so it's not just a glorified looper stuck at the end of my pedal chain.
I replaced it with the Ditto X2, which I really like.
