Hi all,
I'm probably doing something stupid or missing something obvious, but I need some help troubleshooting some noise I'm getting in my rather gainy metal setup. I'm playing through a Victory Kraken with a Line 6 POD HD500X hooked up four-cable method to cover all my effects. Now until recently, I was using the noise gate in the POD, but there's so much gain in the Kraken's second channel that I was having to have two noise gates in the internal signal path, and they're not the best.
So my solution was to get a Boss NS-2 and stick everything in the loop of that so that the noise gate is getting my pure guitar signal and then isolating noise from the rest of the rig. In theory, very straightforward, but something about introducing the NS-2 to the rig has resulted in some serious high pitch squealing under high gain. I either use the POD for pre- and post- effects or for simple recording at home, just a Tube Screamer Mini in front of the amp.
Does this sound right to you?
Guitar > NS-2 input.
NS-2 send > pre-amp FX (either just a TS mini or the POD's input)
POD send/TS mini output > amp input
Amp FX loop send > NS-2 return
NS-2 output > (POD return > POD output >) Amp FX loop return
Now without the NS-2, the POD works great in four-cable method - no extra noise, just a little loss of sustain with its internal gates. But as soon as the NS-2 is introduced, it's almost like there's a ton of extra gain (more than what it already has) being introduced from somewhere, so the second channel has way more gain than it can cope with, amplifying what would normally be a little electrical chatter into a constant uncontrollable squeal. Doesn't matter whether the NS-2 is on or off, or if it's on mains (cheap Donner daisy chain that also powers the TS mini) or battery.
Does anyone have a clue what's going on?
Tim
Have you tried putting the second set of Pod effects within the NS-2 loop as well, or does that make it worse? ie, amp FX send > Pod return > Pod output > NS-2 return > NS-2 output > amp FX return.
If that doesn't help, try it with only the amp's preamp in the NS-2's loop, so all the FX are outside the NS-2 loop.
It’s another version of the reason why you shouldn’t put distortion pedals in the FX loop of an amp.
Check that all the jack nuts on the pedal are tight, they can come loose and the grounding goes via them.
