I've got a self assembled Cabronita Tele with a single bridge TV Jones pickup which currently has a single vol and tone.
I'm sure I could live without the tone control so would like to replace it with a three way toggle (which will require only minimal woodworking skills to widen the existing hole slightly - I hope).
I'm fairly certain that I should be able to wire this up so that one position on the selector gives me just pickup > volume > output and another will give pickup > volume > 0.0047 cap > output. If I'm right, the remaining position would cut the output?
Can anyone point me to a wiring diagram showing how this should be done? And for bonus points, is there anyway that the third position could be used to switch the humbucker from series to parallel or would this require a push/pull pot to be added in to the equation?
I should add that the body is rear routed for 2 pots and I'm not keen on changing that, for example to fit a regular tele control plate, I'd prefer to just have the single vol and 3-way switch combo.
A 4P3T on-on-on switch will do the job.
IMO, it would be wise to retain the tone control. Engage the Eldred mod network via a push-pull pot under the tone control.
And you can use those whether the pickup's split or not.
