As in the Title, it appears to have developed this problem to a point where it is now annoying and I want to use this Guitar for a Gig at the end of the month. It didn't seem that bad when I was gigging regular and it has been in it's case (as it always is) but obviously still played at least once a week.
Do I spray in Contact Cleaner by removing the back panel and spraying directly into the business part of the pots or by removing the knob and spraying from the exterior of the Guitar? I'd rather not have to take off the knobs.
If spraying from the back, can I be liberal with the spray, as in does it matter what else it touches as it evaporates away doesn't it?
Access at the back is the same as a Les Paul.
Thanks!
Only a Fool Would Say That.
D-Tuna, Floyd Rose Locking Trem, Basswood Body, Maple Cap, Birdseye Maple Neck, Vol and Tone Knob, 25.5 scale, 15" Radius of Fingerboard.
The neck is the best neck I have ever played on any Guitar, it is an asymmetrical profile.
Just so comfy, rounder on the thumb side, slimmer on the finger side, makes movement easier to me. It has the slightly slimmer nut width of 41.2mm
The pick ups are very good, quite "Hot" a lot of Bark on the Bridge, really Fat Neck Pick Up tone and the inbetween position is very full too.
There are a lot of different models of these Guitars, Specials, Deluxes, Special Deluxes, Special EXP. I know nowt about these other than some are USA made and some are Korean. I can't compare to later Fender/Charvel models for quality etc as I ain't played or heard them.
Hope that helps
*The shop doesn't know what the price is. And hasn't known for a week now. Bit weird.
