I had wrote a longer post but it bored me reading it back so I've trimmed the fat!
Got an SG Junior thanks to
@guitars4you (I'll pop a NGD up once past the honeymoon period so I don't just gush like a teenager etc) and he'd strung it with 9.5s. I didn't necessarily want to like 9.5s because they're harder to get, limited choice of brands etc.
I thought I was a 10s man and pure nickel all the way (rotosound being the particular easy choice)...but I've wound up questioning that and now my Les Paul is sat with some 9.5s on which are just bedding in for proper testing, having tried 9s and hybrids.
So anyone else gone through similar re-evaluation? And does anybody know of any pure nickel 9.5s or want to suggest the best 9.5s for classic rock and blues?
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
https://www.ebay.co.uk/itm/PRS-9-5-Electric-Guitar-Strings/183381177718?hash=item2ab25eb576:g:AtIAAOSwBahVFq2K&frcectupt=true
Just a thought - Why not try 10's and de-tune 1/2 a step
Hope you are enjoying the SG
All ‘pure nickel’ strings are pure nickel *wound* - they all use a steel core, nickel wouldn’t work. The difference is between pure nickel wound and nickel-plated steel wound.
I wind up playing too much stuff in standard so bit of a creature of habit in that sense. I'd maybe consider otherwise if I wasn't mainly playing along to the record at the moment. SG feels great, currently bouncing between it and Les Paul as mood suiting.
Yeah, knew about steel core (and obviously the plain strings being steel regardless) - pure nickel is just that bit darker for me. It may just be a case of tweaking other stuff i.e. amp EQ since 9.5s with a hair more relief in neck compared to 10s might have hit the goldilocks zone on the Les Paul in terms of feel. Will put in a bit more time to be sure.
I didn't know about the tension perspective, that's interesting to know. How does that work out for other gauges out of interest, assume there's some known maths behind?
Where I tried out anyway:
10s - nicely buzz free, little work on some bends/vibrato especially first finger.
9s - bends and vibrato happy days but buzz city outside the high 2 strings, especially at 2nd position.
hybrids - G still a bit buzzy open through 4th, depends how digging in.
9.5s - kinda felt like reasonable compromise between 9s and 10s (obviously) and the little bit of buzz was either play with a lighter touch, or seems to have hopefully been counteracted by truss rod which I gave a slight turn last night and checked briefly this morning.
I've known about the problem with 9s as soon as I started being aware that there were different gauges of strings! - it's just obvious, when you look at the step changes within the sets... 9-11-16 vs 10-13-17, it's clear that the 11 B in the 9s is too light given that it's five semitones below the E and only four above the G.
That sounds like a truss rod adjustment issue.
Although I do find 9s a bit too buzzy anyway, because I play like a lumberjack
I intend to keep that with 9s for standard tuning, then keep the strat on 10s which is often down to Eb for a different band & singer.
Recently went to a Jam and played a friend`s Gretsch with 8s - thought I`d really struggle, but was actually ok! Although I did find it lacked a bit of `fight`
I'm a weird combo of digging in while playing, but relatively weak on bend strength.
Ordered some of these, just finished stringing up the SG...lost a bit of volume compared to the strings Mark had put on (think D'addario 9.5 XLs if I was guessing although volume wise makes me wonder if they were NYXL). They're also a little buzzier, so guessing a little lower on tension. Weirdly the treble strings though are a bit firmer - especially the E. Gonna let them settle in, might just give truss rod a tweak here if the buzz still needs taming.
Sound wise, I'm a fan. Not tried with bigger amp and only just restrung (so judgement reserved), but there's a bit more thump and meat to such as power chords. I've snuck the tone control up a bit for home base where I like things (was 5.5, now 7.25). Although at the same point, the NYXL 9.5s I popped onto my Les Paul have settled nicely after a week of use and it's no longer twangy enough that my Telecaster is jealous!
Would be eternally grateful
