I suspect the answer to this is "get a different pedal" (which may morph into "get a multi-FX" because I'm not convinced I can be arsed with lugging the big bugger around anymore) but just in case …
… I have a Boss PH-3, and I do like the phasing sounds it produces. But it does introduce a significant volume/output drop when it's engaged. If it was always-on that wouldn't be a problem, but generally I only use it for the odd song now and again, so it's a total pain.
I assume there's nothing that can be (easily) done to the pedal to fix it, and that my only options are:
- replace it
- set everything up with the volume pedal backed off a bit, then max it out when using the phaser
- set up a clean boost to compensate for the drop and engage that with the phaser
It's already on a loop switcher and makes no difference what other pedals are or aren't engaged.
I'll go update the ebay watch lists ...
there was on for sale on here, I was eying it up. possibly @wiresDreamDisasters selling ?
