Would someone please advise me as to why the neck tone pot on my Les Paul is not working? I've wired it exactly the same as the bridge tone control, which works fine.
Thought it might be a faulty cap - changed the cap, still no joy...
The third terminal is connected to earth - not visible in the pic.
I've checked and there are no dry solder joints
The pot itself seems to be working - I tested it with a multimeter (in situ as soldered). When I turn the pot, the resistance does drop slowly down to 0.
Expert opinions deeply appreciated...
[Imgur](
https://i.imgur.com/x8IxUe1.jpg)
[Imgur](https://i.imgur.com/RHDcjzE.jpg)
[Imgur](https://i.imgur.com/CfQeqJ2.jpg)
Test for continuity between the metal exterior of the push-pull pot and a permanent ground point, such as another pot chassis or the output jack socket.
The anti-corrosion coating on those pots can be a PITA when soldering. I always scratch through it to ensure a reliable connection.
You are measuring the wrong side in the second picture.
Also what Funkfingers said - where is the pot chassis grounded to? I can’t see in the pic.
An occasional problem with push-pulls is a poor electrical connection between the two parts of the casing, even though both are metal and they appear to be in contact via the crimp tabs. If everything else seems to be ok, check that and if necessary solder a short wire between the two.
From terminal 1 - I had soldered a wire to the pot chassis, so it was very much grounded, and all four pot casings are linked to each other (Thanks Funkfingers).
The 2 separate parts of the pot casing (very relevant point John) - for this particular pot there is good electrical continuity.
