I realised that this was going to be a little challenging. The RC3 has 2 inputs, input A and B; A being mono. I put the bass direct into A on the RC3 and using the 'main right' output on the SR16 connected it to input B on the RC3. The RC3 has 2 outputs, again A and B with A being mono. However, the head only has one 1/4" jack input on the front. So used an ancient stereo Y splitter jack in the amp's input jack and ran 2 leads out of the two outputs on the RC3 into the two jacks on the splitter. This actually worked but the volume on the head was reduced a fair bit.
There doesn't appear to be any way to go direct into the SR16 and then out of that and into the RC3 so I'm a bit stumped; other than midi and I have never used midi before. However, there are connectivity options on the back panel of the head. Its a Behringer BVT4500H. The rear panel has a Speakon output and also 2 x 1/4" unbalanced outs. Then 2 x 1/4" jack effects loop (send/return) and also a 1/4" power amp input and preamp output. Finally it has a Line Output with balanced XLR out, ground lift, level knob and pre/post button. It also has a tuner out. I simply have no idea if any of the above would allow me to connect the RC3 and the SR16 so that a) I don't have a major loss of volume and b) be able to use the SR16 through the amp and actually record bass and drums via the RC3.
I probably haven't explained this very well but any help would be really much appreciated!
If not you needs something like a Boss LS-2 Line Selector which can be used as a simple 2-channel mixer. You may need to experiment with whether the RC-3 and LS-2 need to be in front of the amp or in the FX loop.
The LS-2 sounds like a really excellent idea and definitely worth a try. I didn't even know such a thing existed. I guess my basic problem is that I don't understand how a FX loop works as I've never actually used one so I think I need to have a look at a few Utube clips so I understand it better. As you say, the LS-2 may work in front of the amp or possibly in the FX loop.
Thanks once again for some excellent advice @ICBM, really appreciate it.
