However, shorter is only ‘warmer’ to a point - 24” Fender guitars suggest that anyway...
The short answer is that it will change the sound far less than popular wisdom says it should. And that’s even given that the pickups will effectively be in slightly different positions, closer to the ‘nut’.
Scale length *by itself* doesn’t actually matter. It’s the effect it has on almost every other variable that does.
