Hi all.
I have always sruggled achieving a decent metal/rock guitar sound for recording. Admittedly, I am a novice with mixing, etc.
My question would be, how do you folks here organise your guitar sounds, for example, EQ, compression, etc.
I use Reaper as my DAW and wondered if it is best to EQ the guitars in Reaper before fx or do all the eq-ing in the fx, and in this case I am using BIAS FX. Also, would it be beneficial to do some post EQ in the DAW?
I also recently used an EZ Mix package - Metal Gods III (I think is), but still can't seem to manage to get a decent tone in the DAW along with the other instruments.
I hope my post makes sense.
Cheers all!!!
Thank you for the useful info with VSTs, Polarity!
Thank you for the info about setting things up, Equal! Hopefully, I will understand this soon!
Thank you for that, Polarity!
Just learn your amp sim's capabilities, and pick some decent IRs (the blends in the free Ownhammer pack are great), and get a good tone there.
It's only once you've got that far that you should be messing with DAW EQ/compression/etc, and even then it's only to make the various instruments sit right together.
Basically...if you can't get a good tone with your sim on its own, no amount of futzing around in the DAW is going to help you.
I kind of thought it would be up to the the person who mixes/masters to bring out the guitars, but also know that I need to put in the work for the sound before it gets to that stage. Basically, I am kind of happy with the fundamental guitar sounds, but they lack that ummph. If that makes any sense.
Pull in a track you like the sound of, and use low and high pass to isolate the tones you like, make some notes and try and boost the frequencies you like in your own track, or cut if you prefer. Once you get used to the bands you like, you'll be able to dial it in more often.
I also prefer to use the free options listed above, tried Bias but thought it was too complicated for my needs.
IRs have a massive effect on tones, so sometimes its better to stick to a few limited options and work from there.
Obvs, YMMV.
cheers
andy k
Thank you for the advice and info there, Andy! Much appreciated!
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
