Want to see how easy it is?
https://www.dropbox.com/s/kis97jr2qk5p6hy/Bigsby.mp4?dl=0
All you need to do is this - bend the string round the end of your thumb first.
Gretsch G Love Corvette with TV Jones Supertrons, metal LSR roller nut, upgrade wiring & pots, locking Grovers, Tru Arc Serpentune solid bar bridge, upgraded Bigsby B50 with BricksBigsFix Tuning Stabiliser, and @Corvus upgrade Bigsby arm (freakin awesome arm), and BricksBigsFix Squishy spring.
I love this guitar, I used to hate the Bigsby on it, but now it’s spectacular. Of all the mods, the one that impressed me the most was the @Corvus arm. It’s a weighty piece of machined steel, but it’s the perfect length - getting the arm closer to the neck pickup (where I like it), it doesn’t flex like the tin foil arm that came with the guitar, Most impressively, the combination of length, weight, and stiffness have a hugely complementary effect on the Bigsby - the lightest of touches gives the perfect Bigsby Wobble. Where the stock unit was stiff and terrible (I had to ram the guitar into my hip to get the B50 to wobble (then go out of tune), now it’s soft, delicate in use, and excellent in every way. It’s on par with the best B6 Bigsbys.
Fantastic work @Corvus, let me know when you’re up and running again, would love to buy another.
https://imgur.com/a/AmF831j
^ that kind of thing's ideal; no tension bar, ideal bridge, straight-ish string run through the nut.
@Marlin cheers, doubt I'll be making any more unless I get me a small lathe. Arms are easy, making the tips on a pillar drill is v.slow and hit & miss
http://www.alleykat.co.uk/images/stuff/jazzbastard/p8/2_rod_drilling_jig.jpg
http://alleykat.co.uk/images/stuff/shimmerkaster/bigsby/bigs_handle.jpg
Have you still got the white Corvette? Loved that ... quite fancy making one a bit like Mr Reuben's super cool white & pink one, vid link
lobe that white and pink one....hmmm....maybe time for a new pickguard
